Export face as figure
dforchheimer
Post by dforchheimer »
In Protocase Designer 5 I used to be able to export a face as a figure (I believe I could get SVG, but maybe it was only PNG). After clicking around for quite some time I can not figure out how to do that in PD 6. I can see the option to print a face, but that doesn't allow me to print to file. Does the feature still exist, and if so, where do I find it? I need this feature because I prefer to work on the graphics separately in Inkscape rather than directly in PD.
I'm running Protocase Designer 6.1.15 on Linux
Cheers
Daniel
Re: Export face as figure
I think you are looking for the Export/Import Graphics template. Open the face editor and go to IMPORT/EXPORT section and click the drop down and choose Export Graphic Template then click go. It should save a PNG of the current face.
Best Regards,
colteat
Post by colteat »
dforchheimer wrote:
Mon Oct 02, 2023 11:03 am
Cheers
Daniel
Hi Daniel,
You’re not missing anything obvious — PD6 removed the direct “export face” feature that existed in PD5. In PD6, printing faces to file (SVG/PNG) isn’t supported anymore, even via the print dialog. The usual workaround is to export DXF of the panel and bring that into Inkscape, or stick with PD5 for graphics prep. Might be worth emailing Protocase support; they’ve acknowledged this regression before.
jacksonmark
Post by jacksonmark »
I understand how frustrating it can be when familiar features change in new software versions. In Protocase Designer 6, the export options might have shifted. Have you checked the "File" menu for any export or save as options? Sometimes, features like exporting to SVG or PNG are tucked away in submenus. If you still can't find it, consider reaching out to Protocase support—they might have the latest info on this feature.
danielwilkins
Post by danielwilkins »
It looks like the export functionality changed a bit in PD6 compared to PD5, so you’re not the only one having trouble finding it. From what I’ve seen, the old “export face as image/figure” workflow is either hidden or removed in newer versions, especially on Linux builds.
Your use case makes perfect sense though — editing panel graphics in Inkscape is much more flexible than doing everything directly inside PD. Hopefully the developers can either restore the direct SVG/PNG face export or make it easier to discover in the UI, because it was definitely a useful feature for front panel design workflows.
