In Protocase Designer 5 I used to be able to export a face as a figure (I believe I could get SVG, but maybe it was only PNG). After clicking around for quite some time I can not figure out how to do that in PD 6. I can see the option to print a face, but that doesn't allow me to print to file. Does the feature still exist, and if so, where do I find it? I need this feature because I prefer to work on the graphics separately in Inkscape rather than directly in PD.
I'm running Protocase Designer 6.1.15 on Linux
Cheers
Daniel
Export face as figure
Re: Export face as figure
I think you are looking for the Export/Import Graphics template. Open the face editor and go to IMPORT/EXPORT section and click the drop down and choose Export Graphic Template then click go. It should save a PNG of the current face.
Best Regards,
Best Regards,
