Minimum case sizes?
agulliver
Minimum case sizes?
Post by agulliver »
I've tried inputting size information for a couple of designs but get a message telling me the height (30mm) is outside the limits for the software. Is there anywhere I can find out these limits?
andy
Re: Minimum case sizes?
Here are the dimension limits:
  • Rackmounts:
    • Height: 1U to 9U
    • Depth: 2" to 46" (50.8mm to 1168mm)
  • U-Shape:
    • Height: 1" to 22" (25.4mm to 558.8mm)
    • Width: 1" to 46" (25.4mm to 1168mm)
    • Depth: 1" to 46" (25.4mm to 1168mm)
    • Additionally, if the box is more than 3"x3"x3" (76.2mm x 76.2mm x 76.2mm) the Width and Depth each must be at least 2" (50.8mm) greater than the Height.
  • L-Shape:
    • Height: 1.5" to 22" (38.1mm to 558.8mm)
    • Depth: 1" to 24" (25.4mm to 609.6mm)
  • Flat Panel
    • max of 95"x47" (2413mm x 1193.8mm)
agulliver
Post by agulliver »
Thanks for that - just what I was looking for.
Andy
You are welcome, thanks for pointing out a piece of information that was missing. I will be adding it to the resources webpage at http://www.protocasedesigner.com/resour ... erials.php and future versions of protocase designer will give more useful error messages.
