This is a templated face, and cannot be edited.
Zain
Post by Zain »
Greetings,
I am trying to modify part of an ATX Assembly template but am prompted with the following error: "This is a templated face, and cannot be edited." How can I modify the area above the rear I/O panel of the chassis? It's the part in green in the attached image.
Rear of Chassis.PNG (24.71 KiB) Viewed 30486 times
I would like to add some 80mm fan cutouts and or vent cutouts.
TIA,
Zain
Zain
Re: This is a templated face, and cannot be edited.
Post by Zain »
Below is the screenshot of the error.
Error Popup.PNG (36.44 KiB) Viewed 30470 times
The PDA file is located on my GDrive as it is too large to post here.
https://drive.google.com/file/d/1dAQ2jh ... sp=sharing
Hello Zain,
Some faces are not editable due to manufacturing reasons. However in this case I think it's fine. I have set the particular face you are wanting to edit as editable. Attached is the file.
24x20x8.75 Case - Black.zip
Updated Computer Enclosure Unlocked Front Flange
(1.45 MiB) Downloaded 3599 times
Best Regards,
Zain
Post by Zain »
Awesome, thanks!
