Hello Ti-Paul,
I really thought we had this solved. I'll be looking into the linux build to day and get back to you.
Thanks for the heads up.
						Protocase Designer 5.1.0 hangs on Fresh Ubuntu 20.04
Re: Protocase Designer 5.1.0 hangs on Fresh Ubuntu 20.04
Can you post any errors in the debug.0.log here. It's normally found in ~/ProtocaseDesigner/
I tried a vm and got stuck but I think it had to do with my setup of the vm. I believe we have an issue 3rd party library, Jogl, that we use in PD. Maybe try different versions of it. Am personally going to try this next.
Thanks Matt,
Here's the debug.0.log in attachment.
- debug.0.log.zip
 - (5.22 KiB) Downloaded 1843 times
I have the same issue running on Red Hat Enterprise 7.8, using the included jre.
Hello trungdok,
We just made an update to the Linux build. This build has a fix for ubuntu 20.04 and should work. Try the latest version and if you don't mind I would like to know if it works or not.
Here is the download. https://www.protocasedesigner.com/downl ... p?format=5
Another thing, you may need to uninstall. Here are the uninstall instructions.
Default PREFIX: /usr/local/
Replace all instances $PREFIX with what you entered when installing the software.
rm -rf $PREFIX/bin/ProtocaseDesigner.sh
rm -rf $PREFIX/share/Protocase\ Designer\
rm -rf $PREFIX/lib/Protocase\ Designer\
rm -rf ~/ProtocaseDesigner\
