Export issue with custom cutouts in Protocase Designer
Hi everyone, I’m having an issue when exporting a design with several custom cutouts in Protocase Designer. After exporting the file and reopening it, some of the cutout dimensions seem slightly shifted or misaligned compared to the original design. Has anyone experienced this before, and is there a recommended way to ensure cutouts stay perfectly accurate after export/import?
Jorgntrell
Re: Export issue with custom cutouts in Protocase Designer
Has anyone had trouble with Protocase cutouts shifting on export/re-import? I've noticed it, particularly with complex shapes. My fix has been to slightly oversize the cutouts initially, then use a precise drill bit for final adjustments after the part arrives.
Is this a common problem or is there a better method? I'm a bit worried about inaccuracies in my next five nights at freddy'sanimatronic build! https://fivenightsatfreddysgame.io
fadedsever
Has anyone seen issues with Protocase cutouts moving during export and import? I've observed that, especially with intricate shapes.
https://basketballstars-2.io
parreltrysail
Yes, this can happen due to rounding or grid snapping during export/import. Make sure all cutouts are aligned to the same reference origin and use consistent units (avoid switching between mm/inches). Exporting in a native or lossless format and disabling auto-adjust/snap features usually helps preserve exact dimensions.
Luis Cooper
sanctionarticle
Yeah, I’ve run into something similar before. In my case it turned out to be a mix of snapping and grid settings not matching after re-import, which caused tiny shifts in the cutouts. I’d suggest double-checking that your units and grid/snap options are identical before exporting and after reopening. Also, exporting to a different format (like STEP instead of DXF) helped preserve accuracy better for me. If it keeps happening, it might be worth reaching out to Protocase support—they’re usually pretty responsive with this kind of issue.
surgeryproclaim
I found the talk about slope-free design quite interesting, especially how it might reduce assembly complexity. I am curious about the practical applications you have observed in real-world projects. What advice would you provide to someone who is just starting to explore this subject in their own fabrication work?
