In protocase designer 4, it does not identify the .cas files from the earlier version. I go directly to the file location, but it does not see it. Nor when I use the windows search tool does it even locate the files, but protcase version 3.?? will load them easily.
Any suggestions?
Protocase 4 and earlier .cas files
Re: Protocase 4 and earlier .cas files
The import of old versions is now functional and the browser should allow you to see the file.
I have just installed Protocase Designer and a .cas file generated by an earlier version will not load into the software. It can be seen in the browser.
I am sorry I did not get back to you sooner - the forum notifications don't seem to be functioning correctly. If you would be so kind as to send your cas file to info@protocase.com and mention that you tried to import it into Protocase Designer 4 I will take a look at it and see why it won't import.
