Open Compute Project
APLH94
Post by APLH94 »
Im looking to design a 1U enclosure for an OCP (Open Compute Project) compatible rack. Anyone ever done this or able to point me towards good CAD as a starting point? OCP enclosures are 21" wide and not your standard 19". Please!
Macaulay
Re: Open Compute Project
Post by Macaulay »
APLH94 wrote:
Mon Jun 23, 2025 9:44 am
You can adapt in CAD to your specific hardware and cooling needssex dolls usa :shock:
seraphina
Post by seraphina »
quietbreezy
Post by quietbreezy »
Yes, OCP racks are 21” wide (instead of the standard 19”), and they follow the Open Rack standard (typically based on the Open Rack v2 spec). If you're designing a 1U enclosure, I’d recommend starting with the official mechanical drawings from the Open Compute Project site.
Are you targeting Open Rack v2 or v3?
MarjorokBaier
Post by MarjorokBaier »
Designing a 1U OCP enclosure is a neat project! Finding CAD files for those wider 21" racks can be tricky. It's a bit like trying to escape Granny's house - you need the right tools and a solid plan. I haven't personally designed one, but maybe check OCP's website for resources, or look for similar open-source hardware projects. Good luck with your build!
cohortknowledge
Post by cohortknowledge »
Hey, I ran into something similar when looking at OCP hardware. One place I’d suggest starting is the official specs from the Open Compute Project, especially the Open Rack V2/V3 mechanical design files. They usually include detailed dimensions for the 21" equipment bay and the OpenU (OU) height units, which are slightly taller than standard rack units. A lot of people I know import those spec drawings into SolidWorks or Fusion and build their enclosure around that reference. If you haven’t checked yet, the OCP site should have the mechanical spec PDFs and sometimes STEP files for rails and rack geometry. That might give you a solid baseline for designing a 1OU chassis that will actually slide into a 21" rack correctly.
EmmaAlva
Post by EmmaAlva »
Many individuals I know take those specification drawings and import them into SolidWorks or Fusion to design their enclosures based on that reference.
https://tinyfishing.co
