When using an imported 3D component, it is possible to set the offset height of the part. I have Protocase Designer set to use millimetres, hence the OffsetHeight field is displayed in mm. However, when I enter data in this field, the input seems to require inches - for instance, entering "1" will result in 25.4mm being displayed, "2" results in 50.8mm and so on.
Can this bug be added to the queue to be fixed?
3D Component OffsetHeight Input Units
Re: 3D Component OffsetHeight Input Units
Yes, this definitely sounds like a unit mismatch bug. Submitting it to the Protocase team for a fix would be the right step. Thanks for reporting it.
