Hello I am building a custom gaming pc, here are the parts:
Intel 6700K CPU: http://goo.gl/gm9dA6
EVGA GTX Titan X: http://goo.gl/emtaq0
ASUS Z170 Deluxe Motherboard: http://goo.gl/CDs9W2
Corsair Vengeance DDR4 Ram: http://goo.gl/M6zinq
NZXT X61 CPU Cooler: http://goo.gl/2ohJ3R
NZXT 140mm LED Fan: http://goo.gl/vj1NGb
NZXT 120mm LED Fan: http://goo.gl/tCXcoU
Corsair AX1200i PSU: http://goo.gl/8WRnca
Intel 750 PCI-e SSD: http://goo.gl/N0aohe
Custom Mods/Cables: http://goo.gl/ZR55qM
White LED Strips: http://goo.gl/JWsmkG
I was wondering how I could put the motherboard mounts in and cable management in and how I could fully know exactly where everything would fit and go. Also how could I make I.O. mounts. Not exactly sure, do i need to download more content? I am using protocase.
Ilyas
I am building a custom gaming pc. I have several questions:
YoungColieo
Re: I am building a custom gaming pc. I have several questions:
Hey YoungColieu,
I'd like to show you our new computer templates. In order to use these, you will need to download our beta version of designer, found here: http://protocasedesigner.com/RELEASE/pr ... c24,15.exe
Once you download this version, you will be able to use our computer case templates. I have attached a file of our ATX motherboard template. This will take care of the motherboard mounting, as well as the I/O cutouts. Also, there is a cutout for the ATX PSU. You can edit the size of the enclosure by clicking 'Edit' (top toolbar) -> 'Enclosure Properties'. (Please ignore the design errors related to the ATX PCI CUTOUT and the CompositePath - Objects intersecting exclusion zone.)
From here, you will need to create the cutouts for mounting each component (fan, radiator, etc.). Protocase Designer has a cutout library, which already contains a cutout for your 120mm fan. Here is a link on how to use the cutout library: http://www.protocasedesigner.com/wiki/i ... ut_Library.
Unfortunately, Protocase Designer does not feature 3D models of components. When placing the cutouts, you will need to factor in the space needed for each component, making sure that there is no interference within the case. You can add notes onto these cutouts, to help provide information on what the cutout is for, or any specific details you feel are necessary.
Alternatively, you can use the Design Services offered by Protocase. Our Design Services team will be able to take your components, and tailor the enclosure to accommodate them.
I hope that this helps answer your questions and gets you started on having a cool case for your gaming pc. The custom computer enclosure templates are a relatively new pursuit for our Protocase Designer software, so I would love to hear any feedback you have.
- Attachments
- GamingCase.pda
- (129.01 KiB) Downloaded 1512 times
YoungColieo
Thanks so much!
No problem at all, feel free to contact me on here or through email (cpoushay@protocase.com).
I also have a cutout file for the 140 mm fan if you would like to use it!
