Bug Report:New Rackmount w/ mounting brackets in mm broken
jonathanw
Post by jonathanw »
Hi
In 4.4.9-Jun19 and Jul07 (Linux x64):
The Rackmount with mounting brackets template seems broken when using millimeters: Creating a new rackmount causes the main window 3D section to not display any content (it doesn't redraw, just displays whatever was last above it, the menus still work however)
Saving and reopening does not help.
There does not seem to be any errors in the log, either.
Creating in inches, switching to mm and reloading, does work though; and I can also edit the properties in mm once the 'inch' version is loaded.(in Jun19 at least)
Good luck with the fixes,
--Jonathan
Re: Bug Report:New Rackmount w/ mounting brackets in mm broken
Hello again, and thank you for all the detailed trouble-shooting! This is an important bug and we will get to it right away.
