I'm using version 4.4.5 on WinXP.
Enclosure type is 1U Extruded Aluminium Type B.
I have created my design and while reviewing everything I realized I need to increase the enclosure width and depth by 1mm, for a more comfortable clearance from the end of the PCB.
All cutout, graphics and PEM dimensions relative to the datum will not be affected.
However while I can change the width and depth on the "Edit enclosure properties" form, then click "OK", the dimension has not changed if I open up the form again.
I don't have to start again, do I?
Simon.
Edit enclosure properties - Dimensions
Re: Edit enclosure properties - Dimensions
Hey,
I don't think that you will need to start again. Can you please download this version of designer and try resizing your enclosure in it?
http://protocasedesigner.com/RELEASE/pr ... -4.4.6.exe
Please, let me know if you have any issues, you can email me directly at david.hines.01@gmail.com or dhines@protocase.com
Hi David,
I have downloaded and installed v4.4.6
I tried increasing the width from 425 to 426mm, again nothing had changed when I re-opened the properties window.
However, I then tried changing the width to 430mm, which worked.
I then changed the width to 426mm, which again worked.
Having a play with some values, it seems the software will not accept a change under 3mm.
So the present workaround seems to be to increase the size by (n+3)mm, then decrease the size by 3mm.
Simon.
Simon.
Very interesting, thank you for noticing this and bringing it to our attention! A very peculiar problem indeed.
