The cutout library stopped opening today. I am selecting it from the Cutout Library and Fasteners drop down menu and then nothing happens. This issue just started today. Any ideas?
cutout library not opening
Re: cutout library not opening
Can you look in your My Documents\ProtocaseDesigner\ directory for debug.0.log and post it?
<debug>@JDesigner.Main []
<debug>@JDesigner.Main [===============================]
<debug>@JDesigner.Main [==== JDesigner version 4.2.15 - June 14, 2012 Start at 12-07-30 17:09 ====]
<debug>@JDesigner.Main [Os: Windows 7 arch: x86 version: 6.1]
<silly>@addEntry.addEntry [added [version: 4.2.15] to entity]
<minor>@HttpWriter.writeMultipart [I/O Exception - orders.protocase.com]
<minor>@HttpWriter.writeMultipart [entity: org.apache.http.entity.mime.MultipartEntity@1066e48]
<debug>@minor.init [GL Init Ver: com.sun.opengl.impl.GLImpl]
<silly>@com.protocase.viewer.Renderer3D.init [VBO Support: true]
==== exception ====java.lang.NullPointerExceptionNull child not allowed--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(98,9),absolute(390,57),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException: Null child not allowed
at javax.swing.tree.TreePath.pathByAddingChild(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.setParent(Unknown Source)
at javax.swing.tree.DefaultMutableTreeNode.insert(Unknown Source)
at javax.swing.tree.DefaultMutableTreeNode.add(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.expand(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.rebuild(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.setModel(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.setModel(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.propertyChange(Unknown Source)
at java.beans.PropertyChangeSupport.fire(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at javax.swing.JTree.setModel(Unknown Source)
at javax.swing.JTree.<init>(Unknown Source)
at com.protocase.library.FileTreePanel.<init>(FileTreePanel.java:77)
at com.protocase.library.LibraryPanel.<init>(LibraryPanel.java:117)
at com.protocase.library.LibraryDlg.<init>(LibraryDlg.java:22)
at com.protocase.viewer.JDesigner.OnShowCutoutLibrary(JDesigner.java:1947)
at com.protocase.viewer.JDesigner$23.actionPerformed(JDesigner.java:505)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.protocase.viewer.EventQueueProxy.dispatchEvent(JDesigner.java:2148)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
<silly>@com.protocase.library.PartsManager.reRoot [Re-Loaded library: C:\Users\1088308\My Documents\ProtocaseDesigner\library]
<minor>@PDReader.parsePDSummary [Syntax error in file ADAFC4.DXF]
<minor>@PDReader.parsePDSummary [Syntax error in file BNC_RF_Connectors_TE_5227726.DXF]
<silly>@null.importV3 [removed duplacet parser]
<debug>@Parser.Operate [Formula: Length]
<debug>@Parser.Operate [Answer: Length]
<minor>@PDReader.parsePDSummary [Syntax error in file PE9067.DXF]
<silly>@PartsManager.UpdateLibraryOverHTTP [Began updating]
<silly>@addEntry.addEntry [added [action: get_files_after] to entity]
<silly>@addEntry.addEntry [added [target: 2012-07-30 17:08:40.82] to entity]
<minor>@HttpWriter.writeMultipart [I/O Exception - www.protocasedesigner.com]
<minor>@HttpWriter.writeMultipart [entity: org.apache.http.entity.mime.MultipartEntity@3cce95]
<minor>@HttpWriter.getFileNamesSinceLastUpdate []
<silly>@PartsManager.UpdateLibraryOverHTTP [---- files to grab: ----]
<silly>@PartsManager.UpdateLibraryOverHTTP [Done updating]
==== exception ====java.lang.NullPointerExceptionNull child not allowed--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(98,19),absolute(390,67),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException: Null child not allowed
<silly>@addEntry.addEntry [added [target: 2012-07-30 17:09:43.079] to entity]
<minor>@HttpWriter.writeMultipart [entity: org.apache.http.entity.mime.MultipartEntity@f34cdb]
<silly>@com.protocase.viewer.JDesigner.OnLoad [Opening a file]
<silly>@com.protocase.viewer.JDesigner.OnLoad [loading file C:\Users\1088308\Documents\TrustedDocs\transportable ULE Cavity enclosures\laser enclosure.pda]
<silly>@com.protocase.viewer.JDesigner.loadFile [Loading a pda file]
<silly>@com.protocase.viewer.JDesigner.loadFile [Loaded a pda file]
<debug>@com.protocase.things.thing2d.paths.Circle.draw2D [There should not be a thing that has no type but has path objects]
<silly>@Renderer.editFace [Editing face Front Panel]
==== exception ====java.lang.NullPointerExceptionNull child not allowed--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(70,5),absolute(134,53),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException: Null child not allowed
at com.protocase.viewer2D.PartsLibraryAction.actionPerformed(ViewerPanel.java:2616)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
==== exception ====java.lang.NullPointerExceptionNull child not allowed--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(55,9),absolute(1196,66),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException: Null child not allowed
<silly>@Renderer.editFace [Editing face using existing face editor: Front Panel]
==== exception ====java.lang.NullPointerExceptionNull child not allowed--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(116,11),absolute(807,184),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException: Null child not allowed
==== exception ====java.lang.NullPointerExceptionnull--- stack trace ----java.awt.event.MouseEvent[MOUSE_RELEASED,(30,41),absolute(30,89),button=1,modifiers=Button1,clickCount=1] on panel0java.lang.NullPointerException
at com.protocase.viewer.Renderer3D.invalidateThing(Renderer3D.java:487)
at com.protocase.viewer.Renderer3D.setRootAssem(Renderer3D.java:511)
at com.protocase.viewer.JDesigner.OnClose(JDesigner.java:1229)
at com.protocase.viewer.JDesigner$2.actionPerformed(JDesigner.java:173)
<silly>@com.protocase.viewer.JDesigner.OnLoad [loading file C:\Users\1088308\Documents\TrustedDocs\transportable ULE Cavity enclosures\cavity enclosure.pda]
<silly>@com.protocase.viewer.Renderer3D.invalidate [displaying]
It looks to me that there is probably an error or corruption in a file in your library. If you would zip up your My Documents\ProtocaseDesigner\library folder and send it to dronne@protocase.com I will check it out.
My apologies for the trouble, I will get back to you as quickly as I am able.
