add an additional piece
psuter
Post by psuter »
hi
is there a way i can add an additional piece to the case? i need a wall in the middle of a case to basically separate the rear from the front.
regards
pascal
Re: add an additional piece
There is not currently a way to do this in designer, however one of the templates (U-Shape with Divider) has such a divider in it. Also, if you open up the part tree and enter it as notes the tech team will see the notes you entered (be sure to specify how far back you want the divider) and they will include it in your final quote. The divider will not show up in the online quote of course since Protocase Designer will not know about it.
