What is the purpose of construct mode?
Is there a way to create an L bracket inside the case or would that have to be drawn out and submitted separately?
Construct Mode
Re: Construct Mode
Constructs are used for guide lines and such. They can also be used to notate where you would like something done - for instance if you wanted an L-Bracket in your case you could put a construct rectangle around the footprint on each face and send a sketch of the L-Bracket and we would add that to the enclosure.
In the future we will have a tool that lets you make and add brackets, but it will probably take a year of development.
