Cannot save design in Windows 7 Pro x64
frank1985
Post by frank1985 »
Hi
Whenever I click the Save or Save As button in Protocase Designer, no Save window appears. If I close without saving and say yes to "Save current project", no save window comes up and the program doesn't exit either, unless I say No. I get the same thing when I try to import a cutout - clicking the button appears to do absolutely nothing.
Is this one of the things that will be fixed in version 4?
EDIT: This is in version 3.12j, build 909.
Re: Cannot save design in Windows 7 Pro x64
This is not an issue that I have seen before. Could you do the following for me so I can try to recreate the problem? Go through that process and then send me the following files:
c:\Program Files\Protocase Designer\debug.log
and
c:\Program Files\Protocase Designer\error.log
I suspect there may be a windows 7 security issue but will be able to tell easier with that information.
