So far the only way I have been able to run Protocase Designer on a Mac is to install Windows in a Virtual Machine using VMWare Fusion or sun's VirtualBox. When doing so, you must disable the 3D hardware acceleration because so far, both these options are buggy and will crash when using textures.
Disabling the 3D support disables silkscreens in designer but you can still export a template from Designer, make a silkscreen, and submit it with your order.
Protocase Designer 4 (in the planning stages) will be OSX, Windows, and Linux compatible.
Running Protocase Designer on Mac OSX
