Display unit bug when saving/loading file
alext
Post by alext »
Hi
It appears I have found a bug.
If I change my preferences to use a metric unit for the display units, either cm or mm and if I then create a new L-shape design, use the default values, save the design to a file and then load it again, the designer breaks. The screws in the design are visibly missing and certain functions don't work, such as alignment, setting text color etc. I've attached the debug log file which contains a bunch of exceptions.
This does not happen with the display units set to inches. If I open a file saved when the display unit was set to inches, the file loads correctly, no matter what I have the display unit type to at the time the file is loaded.
debug.0.zip
(3.53 KiB) Downloaded 1786 times
Re: Display unit bug when saving/loading file
Hi Alext,
I was not able to recreate the bug you brought up. If this is still causing you problems, I recommend you download our newest beta version of Designer. You can download it through this link :
http://protocasedesigner.com/RELEASE/pr ... -Jun01.exe
