How to put a radius on a flat panel
I have made a flat panel design - very nice software for this. Now I need to put a radius on the corners. Is there a way to put a raius on the corners?
Re: How to put a radius on a flat panel
Hi;
Contact technical support and they will be able to add the radius for you. Indicate it is a designer limitation you are working around with the order. We're working on adding this functionality and a general external contour tool.
Steve
Steve
