Importing Sub Assemblies
graeme paech
I'm new to Protocase Design, so I might be missing something. I'm having issues importing Sub Assemblies. I've created two independent Bracket (.pda) files. When I import the brackets as sub-assemblies into the Personal Library, it doesn't work. It's either trying to import the same master design drawing again, or nothing at all with zero dimensions. I'm running Version 7.0.36.
WilliamBarrows
Re: Importing Sub Assemblies
I think you should import each file one by one, check the import options are correct.graeme paech wrote: ↑Sat Apr 26, 2025 9:34 pmI'm new to Protocase Design, so I might be missing something. I'm having issues importing Sub Assemblies. I've created two independent Bracket (.pda) files. When I import the brackets as sub-assemblies into the Personal Library, it doesn't work. It's either trying to import the same master design drawing again, or nothing at all with zero dimensions. I'm running Version 7.0.36.
jackmarvia689
- Contact:
Try importing each bracket individually, not together, and double-check the sub-assembly import options—this usually avoids the zero-dimension or duplicate master issue.
