Fix for Protocase Designer on Windows
etl17
Post by etl17 »
If Protocase Designer shows the splash screen and then hangs, here is one possible solution:
Disable the Access Bridge technology in the Java configuration files. To do this, follow these steps:
- Navigate to C:\Users\<username>
- Open the file called .accessibility.properties using a standard text editor (Notepad is fine)
- Find the following lines in the config:
assistive_technologies=com.sun.java.accessibility.AccessBridge
screen_magnifier_present=true
- Add a hashmark (#) in front of theses lines
Save the file and voila! Protocase Designer now launches properly!
Best,
--Stefanos
celia
Re: Fix for Protocase Designer on Windows
Post by celia »
Thanks, I was looking for that because I has the same issue
