3D Component OffsetHeight Input Units
Posted: Tue Mar 12, 2024 4:07 am
by patrick_keys
When using an imported 3D component, it is possible to set the offset height of the part. I have Protocase Designer set to use millimetres, hence the OffsetHeight field is displayed in mm. However, when I enter data in this field, the input seems to require inches - for instance, entering "1" will result in 25.4mm being displayed, "2" results in 50.8mm and so on.
Can this bug be added to the queue to be fixed?
Re: 3D Component OffsetHeight Input Units
Posted: Sat Feb 07, 2026 12:23 am
by dhyha
Yes, this definitely sounds like a unit mismatch bug. Submitting it to the Protocase team for a fix would be the right step. Thanks for reporting it.
Posted: Mon Feb 09, 2026 11:21 am
by Mattheurma
I’d recommend reporting it to Protocase support or their issue tracker with a short repro description like the one you wrote they’re usually pretty responsive to clear, unit related bugs like this.
Posted: Mon Feb 09, 2026 11:45 pm
by dissimilar
I can confirm you’re not imagining things — I’m seeing the same behavior on my end as well.
Even with units set to millimetres, the OffsetHeight field for imported 3D components still appears to interpret raw input as inches internally, then converts it to mm for display (hence the 25.4 mm increments). That strongly suggests the UI label is following the global units setting, but the underlying input logic hasn’t been updated to match.
As a workaround for now, I’ve been:
Manually converting mm → inches before entering values, or
Entering the value, then immediately adjusting it visually until it matches the intended offset
Definitely feels like a bug rather than intended behavior, especially since other numeric fields respect the unit preference correctly.
I agree it should be added to the fix queue — thanks for flagging it. Hopefully the devs can align the input handling with the displayed units in a future update.
Posted: Mon Apr 06, 2026 4:41 am
by randybrooks
Thanks for pointing this out—this definitely sounds like a unit inconsistency bug. If the UI is set to millimetres, the OffsetHeight field should accept and interpret values in mm, not inches.
It might be helpful if the team could confirm whether this is unintended behavior or a known limitation, but either way it would be great to see it added to the fix queue. Unit mismatches like this can be pretty confusing during design work.
Posted: Wed Apr 08, 2026 12:15 am
by yokerapeseed
Yes, it looks like a unit mismatch bug—worth reporting so the devs can fix the mm/inches inconsistency in OffsetHeight.
