size for m4 and M3 threaded pocket hole cutout
hautcoeur
Post by hautcoeur »
What are the Hole diameter and minimum depth for a M4 Tapped, for Thread M4 X .7 pocket hole, on a 6mm aluminum panel?
What are the Hole diameter and minimum depth for a M3 Tapped, for Thread M3 X .5 pocket hole, on a 6mm aluminum panel?
Re: size for m4 and M3 threaded pocket hole cutout
Hello hautcoeur,
m3 = approx 3.11mm
m4= approx 4.15mm
those would be min recommended, but in order to get the min actual you would need to pitch to get 2 threads, which is what I would say would be the overall min so say 2mm for the m3, and 3mm for the 4mm approx in order to allow for 2 turns plus some screw clearance.
Thanks, Matt
hautcoeur
Post by hautcoeur »
Hi, thanks for that first reply.
So these are the minimum depth.
But what are the holes diameter?
Thank you
Ops, was focused on the depth. Here you go.
M4 X .7
Diameter = 4mm
Tap drill size = 3.3mm
M3 X .5
Diameter = 3mm
Tap drill size = 2.5mm
hautcoeur
Post by hautcoeur »
Thank you
