I just installed ProtocaseDesigner 6.0.27 on Windows 10 and I'm not able to create any designs.
Getting the following error:
java.lang.UnsatisfiedLinkError: 'long org.jcae.opencascade.jni.OccJavaJNI.new_BRep_Builder()'
at org.jcae.opencascade.jni.OccJavaJNI.new_BRep_Builder(Native Method)
at org.jcae.opencascade.jni.BRep_Builder.<init>(BRep_Builder.java:69)
at com.protocase.cad.model.CadExchange.readBrep(CadExchange.java:169)
at com.protocase.cad.model.CadExchange.readBrepString(CadExchange.java:185)
at com.protocase.things.solids.CadSolidThing.importYAML(CadSolidThing.java:100)
at com.protocase.things.thing2d.loaders.HardwareLoader.importCadSolid(HardwareLoader.java:56)
at com.protocase.things.thing2d.loaders.HardwareLoader.finalizeLoad(HardwareLoader.java:31)
at com.protocase.things.loaders.ThingLoader.importYAML(ThingLoader.java:109)
at com.protocase.io.PDReader.processYAMLMap(PDReader.java:445)
at com.protocase.library.FileTreeItem.fetchItem(FileTreeItem.java:273)
at com.protocase.library.FileTreeItem.getItemCopy(FileTreeItem.java:235)
at com.protocase.things.thing2d.importers.Thing2DImportHelper.getThing2DFromFileTreeItem(Thing2DImportHelper.java:1144)
at com.protocase.things.thing2d.importers.Thing2DImportHelper.importByParsedPartnumber(Thing2DImportHelper.java:1178)
at com.protocase.things.thing2d.importers.Thing2DImportHelper.importThing2DFromLibraryYAML(Thing2DImportHelper.java:767)
at com.protocase.things.thing2d.importers.Thing2DImportHelper.importFlatsYAML(Thing2DImportHelper.java:635)
at com.protocase.things.solids.faces.ThickFace.importHelperYAML(ThickFace.java:2579)
at com.protocase.things.solids.faces.PathFace.importYAML(PathFace.java:201)
at com.protocase.things.Thing3D.processComponentElementYAML(Thing3D.java:985)
at com.protocase.things.Thing3D.importComponentsYAML(Thing3D.java:889)
at com.protocase.things.solids.faces.ThickFace.importHelperYAML(ThickFace.java:2572)
at com.protocase.things.solids.faces.Bend.importYAML(Bend.java:292)
at com.protocase.things.Thing3D.processComponentElementYAML(Thing3D.java:981)
at com.protocase.things.Part.importComponentsYAML(Part.java:830)
at com.protocase.things.Part.importYAML(Part.java:748)
at com.protocase.io.PDReader.processYAMLMap(PDReader.java:347)
at com.protocase.things.Part.getPartFromLibraryOrPlaceholder(Part.java:915)
at com.protocase.things.Part.importYAML(Part.java:736)
at com.protocase.things.Thing3D.processComponentElementYAML(Thing3D.java:972)
at com.protocase.things.Assembly.importYAML(Assembly.java:775)
at com.protocase.io.PDReader.processYAMLMap(PDReader.java:343)
at com.protocase.designer.client.dialogs.file.project.NewTemplateDialogController$1.call(NewTemplateDialogController.java:219)
at com.protocase.designer.client.dialogs.file.project.NewTemplateDialogController$1.call(NewTemplateDialogController.java:204)
at javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Is there a workaround?
Thanks!
