Unable to accurately scale SVG graphics in PD.
Posted: Thu Feb 11, 2021 10:44 am
by Chris Knudsen
V5.3.28
While placing our SVG logo I noticed that there are no convenient ways to enter image size.
And even less convenient, is that PD seems to resize/re-scale the image when it's imported... so, it is always necessary to re-scale when placing a new image.
Currently, one can only enter the origin.
Re-scaling must be done with a mouse (cannot enter distance/coordinates anywhere). This is complicated by the fact that the aspect ratio has been changed by PD during import, and the X:Y aspect cannot be locked.
Re: Unable to accurately scale SVG graphics in PD.
Posted: Fri Feb 12, 2021 12:37 pm
Hey Chris,
The aspect ratio not coming in not correctly and is a bug if it is happening.
Good point it would be good to have a tool were you can change the scale exactly. I'll add this for a future feature.
Posted: Fri Feb 12, 2021 12:55 pm
by Chris Knudsen
Opening the file with Inkscape on the left. PD on the right.
No changes made in either program on opening/importing.
The PD SVG import looks to be 'square'.
Posted: Fri Feb 12, 2021 1:19 pm
ah. Looks like it normalizes to 1:1 ... for some reason but that is wrong. Will get a bug fix in to keep the proper aspect ratio. 8-)
Posted: Fri Mar 24, 2023 10:06 pm
by dkonigs
Okay, its been two years. This bug is still there, as are all of the complaints over SVG handling mentioned above.
If I actually care about correctly sized/scaled SVGs, it seems like the only way involves knowing the aspect ratio of the visible content, and manually editing the right part of the .pda file in a text editor to adjust the scaling of the graphic element.
I would not expect any normal user to be able to figure out how to do this, and it feels like practically a miracle that I'm even able to do so. (and only possible because the tool uses plaintext data files)
