Can't install.
edward78
Can't install.
Post by edward78 »
mv: cannot stat '/usr/local/lib/Protocase Designer/lib': No such file or directory
mv: cannot stat '/usr/local/lib/Protocase Designer/natives': No such file or directory
mv: cannot stat '/usr/local/share/Protocase Designer/library': No such file or directory
chmod: cannot access '/usr/local/bin/ProtocaseDesigner.sh': No such file or directory
Run using /usr/local/bin/ProtocaseDesigner.sh
I sudo, so whats wrong?
Re: Can't install.
Hello edward,
Do you know if you have any permission issues on the folder you are trying to install PD into?
Are you installing it in /usr/local ?
Mostly like this has to do with something with you setup but I might be able to help I just don't know what could be wrong.
Ti-Paul
Re: Can't install.
Post by Ti-Paul »
I had the same kind of error output when executing :
sudo ./install.sh
Had to include the bash command as mentioned in the Linux install (https://www.protocasedesigner.com/downl ... ctions.php) :
sudo bash ./install.sh
