Page 2 of 2
Re: Protocase Designer 5.1.0 hangs on Fresh Ubuntu 20.04
Posted: Fri May 07, 2021 8:57 am
Hello Ti-Paul,
I really thought we had this solved. I'll be looking into the linux build to day and get back to you.
Thanks for the heads up.
Posted: Mon May 17, 2021 9:40 am
Can you post any errors in the debug.0.log here. It's normally found in ~/ProtocaseDesigner/
I tried a vm and got stuck but I think it had to do with my setup of the vm. I believe we have an issue 3rd party library, Jogl, that we use in PD. Maybe try different versions of it. Am personally going to try this next.
Posted: Mon May 17, 2021 10:08 am
by Ti-Paul
Thanks Matt,
Here's the debug.0.log in attachment.
Posted: Thu Jun 17, 2021 2:00 pm
by trungdok
I have the same issue running on Red Hat Enterprise 7.8, using the included jre.
Posted: Wed Jun 23, 2021 4:26 pm
Hello trungdok,
We just made an update to the Linux build. This build has a fix for ubuntu 20.04 and should work. Try the latest version and if you don't mind I would like to know if it works or not.
Here is the download.
https://www.protocasedesigner.com/downl ... p?format=5
Another thing, you may need to uninstall. Here are the uninstall instructions.
Default PREFIX: /usr/local/
Replace all instances $PREFIX with what you entered when installing the software.
rm -rf $PREFIX/bin/ProtocaseDesigner.sh
rm -rf $PREFIX/share/Protocase\ Designer\
rm -rf $PREFIX/lib/Protocase\ Designer\
rm -rf ~/ProtocaseDesigner\
