Page 1 of 2
Protocase Designer 5.1.0 hangs on Fresh Ubuntu 20.04
Posted: Mon Jul 06, 2020 11:35 am
by kevinkga
When launching the application it just hangs.
I'm running a Ryzen 3800x paired with an AMD RX570 GPU
Tried the included JRE, openjdk8 and openjdk11 but I get the same error.
Here are the error logs:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.google.inject.internal.cglib.core.$ReflectUtils$1 (file:/usr/local/lib/Protocase%20Designer/lib/guice-4.2.2.jar) to method java.lang.ClassLoader.defineClass(java.lang.String,byte[],int,int,java.security.ProtectionDomain)
WARNING: Please consider reporting this to the maintainers of com.google.inject.internal.cglib.core.$ReflectUtils$1
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
amdgpu_device_initialize: amdgpu_query_info(ACCEL_WORKING) failed (-13)
amdgpu: amdgpu_device_initialize failed.
32 [AWT-EventQueue-0] INFO org.reflections.Reflections - Reflections took 26 ms to scan 1 urls, producing 28 keys and 65 values
Any help would be welcome please
Re: Protocase Designer 5.1.0 hangs on Fresh Ubuntu 20.04
Posted: Tue Jul 07, 2020 11:22 am
Hello kevinkga,
This looks a like a graphic driver issue. From a quick google search it says if you upgrade Mesa it may fix it.
Posted: Wed Jul 08, 2020 11:22 am
by kevinkga
Thanks Matt. I did indeed upgrade the mesa libs and now when I launch it I get:
But it doesn't get past the splash screen. It just sits there. Any advice?
Posted: Wed Jul 08, 2020 11:36 am
by kevinkga
Here is the debug log file
<debug>@com.protocase.files.LoggerFiles.setupLogger []
<debug>@com.protocase.files.LoggerFiles.setupLogger [===============================]
<debug>@com.protocase.files.LoggerFiles.setupLogger [==== JDesigner version 5.1.0 - Jun23,20 ====]
<debug>@com.protocase.files.LoggerFiles.setupLogger [== git branch 34fc5ba3cc3c7184b6d71d843f8489a9c878adcd ==]
<debug>@com.protocase.files.LoggerFiles.setupLogger [== Start at 20-07-08 16:34 ==]
<debug>@com.protocase.files.LoggerFiles.setupLogger [Os: Linux arch: amd64 version: 5.4.0-40-generic]
<debug>@com.protocase.files.LoggerFiles.setupLogger [Default Encoding: UTF-8]
<debug>@com.protocase.files.LoggerFiles.setupLogger [Total Memory: 252MB Free Memory: 226MB Max Memory: 4006MB]
<debug>@com.protocase.files.LoggerFiles.setupLogger [available processors: 16]
<silly>@com.protocase.files.LoggerFiles.setupLogger [Converting Inches to Points using dpi: 96]
<debug>@com.protocase.files.LoggerFiles.setupLogger [executable dir: /usr/local/lib/Protocase Designer]
<debug>@com.protocase.files.LoggerFiles.setupLogger [program data dir: /usr/local/share/Protocase Designer]
<debug>@com.protocase.files.LoggerFiles.setupLogger [library dir: /usr/local/share/Protocase Designer/library]
<debug>@com.protocase.files.LoggerFiles.setupLogger [personal library: /home/kaubeelack/ProtocaseDesigner/UserLibrary]
<debug>@com.protocase.config.Config.readConfig [failed to load config, going with default]
<minor>@com.protocase.library.PartsManager.loadLibraries []
<minor>@com.protocase.library.PartsManager.loadLibraries [====>>>> loading library - ignore unless you have a problem with library <<<<====]
<minor>@com.protocase.library.PartsManager.loadLibraries [====>>>> in which case you should unsuppress warnings<<<<====]
<error>@com.protocase.io.NativesLoader.initOcc [Loading Occ natives from: /usr/local/lib/Protocase Designer/natives]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries [Failed loading libTKTObjDRAW.so.7.3.0
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKTObjDRAW.so.7.3.0: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries [Failed loading libTKDCAF.so.7
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries [Failed loading libTKDCAF.so.7.3.0
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7.3.0: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKTObjDRAW.so.7: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKTObjDRAW.so: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.svg.SVGReader.setBounds [Error when getting the bounds of the SVG document]
<error>@com.protocase.io.svg.SVGReader.setBounds [null]
<minor>@com.protocase.library.PartsManager.loadLibraries [====>>>> Done Loading Library <<<<====]
<silly>@com.protocase.library.PartsManager.loadLibraries [root: /usr/local/share/Protocase Designer/library ver: 6]
<silly>@com.protocase.viewer.rendering.gl.decorations.GLDecorations.getDecorator [Couldn't find a GLDecorator of type SELECTION]
<silly>@com.protocase.viewer.rendering.gl.decorations.GLDecorations.getDecorator [Couldn't find a GLDecorator of type HOVER]
==== exception ====com.google.inject.ProvisionExceptionUnable to provision, see the following errors:
1) Error injecting constructor, java.lang.ClassCastException: class com.jogamp.nativewindow.DefaultGraphicsConfiguration cannot be cast to class com.jogamp.nativewindow.awt.AWTGraphicsConfiguration (com.jogamp.nativewindow.DefaultGraphicsConfiguration and com.jogamp.nativewindow.awt.AWTGraphicsConfiguration are in unnamed module of loader 'app')
at com.protocase.designer.JDesigner.<init>(JDesigner.java:101)
at com.protocase.designer.JDesigner.class(JDesigner.java:54)
while locating com.protocase.designer.JDesigner
1 error--- stack trace ----java.awt.event.InvocationEvent[INVOCATION_DEFAULT,runnable=com.protocase.designer.JDesigner$$Lambda$11/0x000000080010f840@672d2b2b,notifier=null,catchExceptions=false,when=1594222480386] on sun.awt.X11.XToolkit@2b047350com.google.inject.ProvisionException: Unable to provision, see the following errors:
1 error
at com.google.inject.internal.InternalProvisionException.toProvisionException(InternalProvisionException.java:226)
at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1053)
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1086)
at com.protocase.guice.Guicer.make(Guicer.java:18)
at com.protocase.designer.JDesigner.lambda$main$1(JDesigner.java:404)
at java.desktop/java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.protocase.viewer.EventQueueProxy.dispatchEvent(EventQueueProxy.java:40)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.ClassCastException: class com.jogamp.nativewindow.DefaultGraphicsConfiguration cannot be cast to class com.jogamp.nativewindow.awt.AWTGraphicsConfiguration (com.jogamp.nativewindow.DefaultGraphicsConfiguration and com.jogamp.nativewindow.awt.AWTGraphicsConfiguration are in unnamed module of loader 'app')
at com.jogamp.opengl.awt.GLCanvas.chooseGraphicsConfiguration(GLCanvas.java:1513)
at com.jogamp.opengl.awt.GLCanvas.addNotify(GLCanvas.java:609)
at java.desktop/java.awt.Container.addNotify(Unknown Source)
at java.desktop/javax.swing.JComponent.addNotify(Unknown Source)
at java.desktop/javax.swing.JRootPane.addNotify(Unknown Source)
at java.desktop/java.awt.Window.addNotify(Unknown Source)
at java.desktop/java.awt.Frame.addNotify(Unknown Source)
at java.desktop/java.awt.Window.show(Unknown Source)
at java.desktop/java.awt.Component.show(Unknown Source)
at java.desktop/java.awt.Component.setVisible(Unknown Source)
at java.desktop/java.awt.Window.setVisible(Unknown Source)
at com.protocase.designer.JDesigner.showApplication(JDesigner.java:469)
at com.protocase.designer.JDesigner.<init>(JDesigner.java:147)
at com.protocase.designer.JDesigner$$FastClassByGuice$$75a8b3f5.newInstance(<generated>)
at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:168)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39)
at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1050)
... 17 more
Posted: Wed Jul 08, 2020 11:41 am
by kevinkga
Could it be an issue with how the paths are being addressed for the files?
$ ll /usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7
ls: cannot access '/usr/local/lib/Protocase': No such file or directory
ls: cannot access 'Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7': No such file or directory
$ ll "/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7"
-rw-r--r-- 1 root root 1044392 Jul 8 16:28 '/usr/local/lib/Protocase Designer/natives/occjava/linux-x86_64/libTKDCAF.so.7'
Posted: Wed Jul 08, 2020 11:50 am
by kevinkga
The following re-appeared in the logs, despite upgrading mesa.
Posted: Wed Jul 08, 2020 12:35 pm
by kevinkga
I can confirm that I don't see these issues when running
https://www.protocasedesigner.com/RELEA ... .8.5.3.deb
Posted: Thu Jul 09, 2020 9:44 am
Interesting. Maybe something happened in JOGL. We recently updated to support MAC.
I'll keep looking into it in the meantime.
Thanks for the heads up by the way.
Posted: Fri Jul 17, 2020 2:02 pm
Our Linux build for 5.1.0 is back! Give it try and let me know how you fair.
Basic problem, if you are interested, we updated our opengl libraries to support latest version of MacOS and this caused the Linux build to break
For the fix the Linux build is using an older version for now.
Thanks for the patience!
Posted: Fri May 07, 2021 8:47 am
by Ti-Paul
Seems that the 5.4.8 version is still hanging with same debug/error log on Linux Mint 20.1...
I have the splash freezing and the logs report the exact same problem...
