Using the template generator in 4.9.7.2 for:
Rackmount Enclosures -> Rackmount
with Unit Height set to "1U"
Results in a design with asymmetrical exclusion areas on the front panel.
Is this correct? I see nothing in the 3D generation of why the right side would have a higher exclusion feature than the left.
1U Rackmount Default exclusion areas,
- PC_front_Exclusion.png (43.17 KiB) Viewed 3309 times
Re: 1U Rackmount Default exclusion areas,
Hello Chris,
No this is not right. What it is suppose to represent, and exclude users from potentially interfering with, is the flange behind the front panel. I will but this in your support system to have it fixed.
Let me know if you have any other questions.
