linux launch error log
greyltc
Post by greyltc »
<debug>@com.protocase.files.LoggerFiles.setupLogger  []
<debug>@com.protocase.files.LoggerFiles.setupLogger  [===============================]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [==== JDesigner version 4.9.7 - Feb28,20 ====]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [==   git branch 30310d7eadb8a0e1d8f5566b15bc23c0e0f0d9e3   ==]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [==    Start at 20-03-14 15:32   ==]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [Os: Linux arch: amd64 version: 5.5.9-arch1-2]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [Default Encoding: UTF-8]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [Total Memory: 238MB Free Memory: 187MB Max Memory: 3516MB]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [available processors: 8]
<silly>@com.protocase.files.LoggerFiles.setupLogger  [Converting Inches to Points using dpi: 95]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [executable dir: /tmp/protocaseDesigner-linux-amd64/jdesigner/pd]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [program data dir: /tmp/protocaseDesigner-linux-amd64/share/Protocase Designer]
<debug>@com.protocase.utils.dirs.DataDirs.getMainLibraryDir  [main library missing: /tmp/protocaseDesigner-linux-amd64/share/Protocase Designer/library]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [library dir: ]
<debug>@com.protocase.files.LoggerFiles.setupLogger  [personal library: /home/[redacted]/ProtocaseDesigner/UserLibrary]
<debug>@com.protocase.config.Config.readConfig  [failed to load config, going with default]
<minor>@com.protocase.library.PartsManager.loadLibraries  []
<minor>@com.protocase.library.PartsManager.loadLibraries  [====>>>> loading library - ignore unless you have a problem with library <<<<====]
<minor>@com.protocase.library.PartsManager.loadLibraries  [====>>>> in which case you should unsuppress warnings<<<<====]
<minor>@com.protocase.library.PartsManager.loadLibraries  [====>>>> Done Loading Library <<<<====]
<silly>@com.protocase.library.PartsManager.loadLibraries  [root: null ver: 1]
<silly>@com.protocase.io.NativesLoader.getBaseDirectory  [nativesRoot: /tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading libTKTObjDRAW.so.7.3.0
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKTObjDRAW.so.7.3.0: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading libTKDCAF.so.7
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKDCAF.so.7: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKDCAF.so: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading libjocl.so
		com/jogamp/opencl/llb/impl/CLMemObjectDestructorCallback]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading libTKDCAF.so.7.3.0
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKDCAF.so.7.3.0: libTKViewerTest.so.7: cannot open shared object file: No such file or directory]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading AbsoluteLayout.jar
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/AbsoluteLayout.jar: /tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/AbsoluteLayout.jar: invalid ELF header (Possible cause: endianness mismatch)]
<error>@com.protocase.io.NativesLoader.soutFailedLibraries  [Failed loading javax.xml.soap-api-1.4.0.jar
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/javax.xml.soap-api-1.4.0.jar: /tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/javax.xml.soap-api-1.4.0.jar: invalid ELF header (Possible cause: endianness mismatch)]
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKTObjDRAW.so.7: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
		/tmp/protocaseDesigner-linux-amd64/jdesigner/pd/natives/linux-amd64/libTKTObjDRAW.so: libTKDCAF.so.7: cannot open shared object file: No such file or directory]
<silly>@com.protocase.utils.gui.FontFamilies.<clinit>  [Could not access fonts to map]
<silly>@com.protocase.viewer.rendering.gl.decorations.GLDecorations.getDecorator  [Couldn't find a GLDecorator of type SELECTION]
<silly>@com.protocase.viewer.rendering.gl.decorations.GLDecorations.getDecorator  [Couldn't find a GLDecorator of type HOVER]
==== exception ====com.jogamp.opengl.GLExceptionProfile GL4bc is not available on X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f5358c570c0, owner true, JAWTToolkitLock[obj 0x864e66, isOwner true, <3fe0fa54, 7bfb04f9>[count 1, qsz 0, owner <AWT-EventQueue-0>]]], but: [GLProfile[GLES1/GLES1.hw], GLProfile[GLES2/GLES3.hw], GLProfile[GL2ES1/GLES1.hw], GLProfile[GL4ES3/GL4.hw], GLProfile[GL2ES2/GL4.hw], GLProfile[GL4/GL4.hw], GLProfile[GLES3/GLES3.hw], GLProfile[GL4/GL4.hw], GLProfile[GL3/GL4.hw], GLProfile[GL2GL3/GL4.hw]]--- stack trace ----java.awt.event.PaintEvent[PAINT,updateRect=java.awt.Rectangle[x=0,y=0,width=1651,height=1032]] on canvas0com.jogamp.opengl.GLException: Profile GL4bc is not available on X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f5358c570c0, owner true, JAWTToolkitLock[obj 0x864e66, isOwner true, <3fe0fa54, 7bfb04f9>[count 1, qsz 0, owner <AWT-EventQueue-0>]]], but: [GLProfile[GLES1/GLES1.hw], GLProfile[GLES2/GLES3.hw], GLProfile[GL2ES1/GLES1.hw], GLProfile[GL4ES3/GL4.hw], GLProfile[GL2ES2/GL4.hw], GLProfile[GL4/GL4.hw], GLProfile[GLES3/GLES3.hw], GLProfile[GL4/GL4.hw], GLProfile[GL3/GL4.hw], GLProfile[GL2GL3/GL4.hw]]
	at com.jogamp.opengl.GLProfile.get(GLProfile.java:991)
	at jogamp.opengl.GLContextImpl.verifyInstance(GLContextImpl.java:1471)
	at jogamp.opengl.GLContextImpl.setGLFunctionAvailability(GLContextImpl.java:1942)
	at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:395)
	at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765)
	at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648)
	at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586)
	at jogamp.opengl.GLDrawableHelper.invokeGLImpl(GLDrawableHelper.java:1279)
	at jogamp.opengl.GLDrawableHelper.invokeGL(GLDrawableHelper.java:1147)
	at com.jogamp.opengl.awt.GLCanvas$12.run(GLCanvas.java:1438)
	at com.jogamp.opengl.Threading.invoke(Threading.java:223)
	at com.jogamp.opengl.awt.GLCanvas.display(GLCanvas.java:505)
	at com.jogamp.opengl.awt.GLCanvas.paint(GLCanvas.java:559)
	at sun.awt.RepaintArea.paintComponent(RepaintArea.java:264)
	at sun.awt.X11.XRepaintArea.paintComponent(XRepaintArea.java:64)
	at sun.awt.RepaintArea.paint(RepaintArea.java:240)
	at sun.awt.X11.XComponentPeer.handleEvent(XComponentPeer.java:584)
	at java.awt.Component.dispatchEventImpl(Component.java:4965)
	at java.awt.Component.dispatchEvent(Component.java:4711)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
	at java.awt.EventQueue$4.run(EventQueue.java:733)
	at java.awt.EventQueue$4.run(EventQueue.java:731)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
	at com.protocase.viewer.EventQueueProxy.dispatchEvent(EventQueueProxy.java:40)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
	at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
	at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
	at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
	at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
	at java.awt.Dialog.show(Dialog.java:1084)
	at java.awt.Component.show(Component.java:1671)
	at java.awt.Component.setVisible(Component.java:1623)
	at java.awt.Window.setVisible(Window.java:1014)
	at java.awt.Dialog.setVisible(Dialog.java:1005)
	at com.protocase.utils.dialogs.informationalviewer.InformationViewer.showViewer(InformationViewer.java:85)
	at com.protocase.designer.StartupDialogs.startupDialogs(StartupDialogs.java:110)
	at com.protocase.designer.JDesigner.lambda$main$0(JDesigner.java:426)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Re: linux launch error log
Hey Greyltc,
Am wondering what version of mesa you have and what video card and driver you are using?
