https://pastebin.com/k7tXgkqG
This is all I get. The splash pops, and this copy paste was with sudo after the same results without.
I don't see the issue, I just updated Java 8 to java's current. Install.sh ran fine the jdesigner.jar isn't running
Linux Ubuntu 18.04.3 Java output
Re: Linux Ubuntu 18.04.3 Java output
Hi S1ugh34d,
Thanks for you interest in Protocase Designer.
The current version of Designer doesn't work properly with the OpenJDK bundled with Ubuntu.
In an upcoming release, we will be using OpenJDK11, but for now we recommend using Oracle's JDK8 on Linux with Designer.
Let us know if we can help with anything else.
