I updated to 4.6.15 on windows 10 and while trying to make changes to an existing enclosure I found I couldn't change the color of a graphic or text. they are locked in as Blue(Pantone 649c) I thought you used to click the color and a color selection window would open.
How do we change the colors so I can send the design off for pricing?
Thanks.
Version 4.6.15 Can't select graphic or font color
Re: Version 4.6.15 Can't select graphic or font color
Hello Lon,
I looked into it and it seems that the issue you mentioned is a bug on the 4.6.15 version. The good news is, it is fixed on our 4.6.16 release. Please download it from here to fix your issue: https://www.protocasedesigner.com/download/
Thanks for your feedback and feel free to reach us directly at designer@protocase.com if you have any more issues.
Hi Colin, is there a way to fix this issue and keep using the 4.6.15 version? I'm just curious.Colin wrote: ↑Fri Apr 27, 2018 12:40 pmHello Lon,
I got great results with Rad-140 Testolone and looked into it and it seems that the issue you mentioned is a bug on the 4.6.15 version. The good news is, it is fixed on our 4.6.16 release. Please download it from here to fix your issue: https://www.protocasedesigner.com/download/
Hi Hesson,
Unfortunately, no, the issue required a code change to fix, so it can't be fixed in the 4.6.15 version.
Please download the latest version to resolve this issue.
