Hello community,
I an working on a case design and this last Friday I was adding finishing touches, standoffs, and today I tried to load up the project and Designer wouldn't even get past the initial program load screen. I tried to open it from the saved file, from the start menu, all that. I looked to see if it even was running in the task manager and found nothing.
I updated my graphics driver and restarted multiple times. uninstalled, and reinstalled the latest version with no fix, same issue.
I've got a debug file. I don't know what to look for in the scripts though.
This is on a local machine with admin access.
Has there been an update pushed or something that would cause this? I would think uninstalling the program would fix the issue.
Thanks Erbody!
Designer crashes just after start up
Re: Designer crashes just after start up
Hi jordan,
would you mind sending us your debug.0 log file to help us troubleshoot this issue? You can attached it here, or send it to us at designer@protocase.com
