this two templates are different, the one with divider has screws from the front/back panel to the top panel (again closed/sealed EMC/EMI point of view)
but the standard one has no this joint/connection
how can I remove the divider?
U-shape with/without devider
Re: U-shape with/without devider
Hey Bertalan,
the screws on top of the enclosure should be present on either the U-Shape or U-Shape with Divider when the width of the enclosure is over 18". When the width is over 18", there is a flange added to the top of the front and back.
If this flange is not present due to the size of your enclosure, we can definitely make sure your manufactured enclosure has one. Just leave a note on the your design that you would like flanges to secure the top to the base, or pass this information on to the account manager or Engineering and Design Services member responsible for your job.
ok I see, let us move forward with the design and contact you later with special needs...
