Bug: Angled Bracket Angle
nnadeau
Post by nnadeau »
# Expected Behaviour
Angle bracket bend angle be referenced as displayed in the diagram and units be in degrees.
# Actual Behaviour
- Either the unit of measurement is not in degrees or the angle datum is not the same as the diagram
- 90deg is not a right angle:
90deg is not a right angle...
2016-08-31 09_54_32-Protocase Designer - New Unsaved Angled L Bracket.png (42.08 KiB) Viewed 2500 times
- 3000deg is more like 120deg or 60deg depending on frame of reference:
3000deg is more like 120deg or 60deg depending on frame of reference.
2016-08-31 09_54_50-Protocase Designer - New Unsaved Angled L Bracket.png (40.85 KiB) Viewed 2500 times
# System Info
- Protocase Designer v4.5.2
- Win10 x64
Re: Bug: Angled Bracket Angle
You are correct. It seems the angle is being measured as the inside angle. We will get this fixed in the next release. In the meantime, subtract your needed angle from 180 and it should work out fine.
My apologies for the inconvenience,
Protocase
