Painting the outside only?
Posted: Thu Oct 15, 2015 3:42 pm
by Bosef1
What is the preferred method for annotating a model to indicating that it should only be painted on the outside? Should I just draw full-size masks on all the interior faces of the model, or is there another procedure I should follow? Please advise...
Re: Painting the outside only?
Posted: Wed Oct 21, 2015 3:58 pm
You could put a note on the assembly or parts. Please note, our quote will not be accurate as we will have to add some charge for the masking of the insides.
Open the Part Tree from the 3D view, and click on the assembly, and use the note tool on the right.
I'd also put the masking across all the faces on the inside too. That will help it be clear!
