Trying to export the rear side of a 1U case, the exported silkscreen has a problem.
With reference to the attached exported silkscreen, the face layout has an extra blank space on the left side of the image. Where from comes this one ?
At the same time the exported silkscreen of the front panel is ok apparently, however, something is strange here also: the resolution is 5700x516, but a ~two years old silkscreen generated with a Protocase version available at that time is 5700x525 (same kind of case). Which one is right ?
I am also not sure why the exported silkscreen is practically a transparent image with only a few pink areas for holes, instead to mimic the chosen case color (graphite sandtex in my case).
there is something wrong with the export silkscreen template
- rear_export_silkscreen.png (12.87 KiB) Viewed 2867 times
Re: there is something wrong with the export silkscreen template
Thanks for noting this! We don't use this feature much, as most graphics can be added directly in designer, so we missed this bug.
