cannot acess quote system
I have been trying to get a online quote for a couple of rack units that I have designed but it is not working. When I first installed the system it worked fine
Re: cannot acess quote system
I believe I already spoke with you via email, but just in case:
If you visit http://www.protocasedesigner.com/wiki/i ... s_Released you will see a new version from friday, August 21st that fixes this issue.
If you still have any troubles after installing this version, please get back to me and I will help you out.
smallangryboy
Same here, OSX Yosemite and Protocase Designer 4.5.3 - clicking the quote does nothing.
Would you mind emailing your debug.0.log found in your /home/username/ProtocaseDesigner directory to dronne@protocase.com after trying to quote? I will also ask one of the mac users in the office to attempt a quote.
smallangryboy
No problem, will do.
ok, I see something going on here, we should be able to solve this tomorrow and get you something that works.
smallangryboy
Brilliant, that's awesome. Many thanks!
I responded offline but want to include the response here for posterity.
The design had a bracket in it that had a 0.0" corner radius. Unfortunately our program never expected a 0.0" corner radius and so crashed. Changing the corner radius to any positive number fixed the issue (I used .001").
We will fix this in our formulas and it will support 0.0" radii in the next build.
Thank you for your patience!
