there is a mess with the decimal separator
My system is set to use comma as decimal separator. By opening an existing drawing, all dimensions are shown with comma, which is ok. However, when I try to adjust something (say, X origin from 87,01 mm to 87,02 mm) the program gives „Some objects have intersected a face boundary. Continue?” If I press yes, the object moves near to the origin arrows/corner and the new X origin of the object becomes 3,30. The Y axis also gets screwed.
If at the time of changing value I enter manually 87.02 (i.e. changing the comma with a dot), the same error popups, however, now the X turns to 87,02 (i.e. it retains the correct value, while displaying back with comma, as it should) but the Y screws by itself even if I didn't touched the value there. The only way to be able to successfully adjust a position value is to change manually the decimal separator from comma to dot on both X and Y values before pressing enter, regardless if I need to change both or just one of the numbers.
The same apply to width and high of an object (or so I think; until now I wasn't able to successfully modify only the height or only the width of an object, but maybe I didn't tried every combination) and probably on every other place.
How am I suppose to work this way ?
(I am using 4.4.9 from June, on Windows)
Re: there is a mess with the decimal separator
I did find a bug in the code for dealing with Locales. Please try the following version:
http://www.protocasedesigner.com/RELEAS ... -Jul07.exe
Sorry for the trouble!
Yes, this bug has been fixed now. Thanks!
EDIT: different bug moved to the other thread.
