What is the second outside circle that gets added with a countersink? Is it a keep out? It seems too large for a keep out. Also, it doesn't seem to cause a design error if I have the outside circles of two countersinks overlap.
What is the minimum distance required between two centers of #4 82 degree countersink holes? Thanks.
- Doug
New Countersink feature
Re: New Countersink feature
I don't know if I accidently messaged you instead of posting but I swear I replied to this days ago. It may have not gone through, if not, my apologies, and if this is a double reply then it is at least there for people in the future.
The outer circle is the outer diameter of the end of the screw you have chosen to countersink. You should try to keep the countersink's outer circle clear from any intercepting cutouts, other fasteners, etc.
It doesn't pop up a warning though? Can you send me your debug.0.log from your ProtocaseDesigner directory? If you are on windows this is probably in your Documents folder.
David H
David H
David,
I don't think that the circles are correct, then. I assume by "end" you mean "head" diameter. I measured the diameter of the outer circle in the tool for a #6 countersink and it is ~.557 in. It should be more like .279in max based on https://www.guden.com/StaticHtml/Countersink/index.html.
I placed two countersinks so that their outer circles intersect and no error was produced when I did a design check. Debug log below: Startup, load test file with countersinks, perform design check, exit.
- Doug
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger []
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger [===============================]
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger [==== JDesigner version 4.4.5 - Apr03,14 ====]
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger [== git branch 944f159c45a7843127c839d4392f33abd72d4a96 ==]
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger [== Start at 14-05-16 14:59 ==]
<debug>@com.protocase.viewer.DesignerFileManager.setupLogger [Os: Windows 7 arch: x86 version: 6.1]
<silly>@com.protocase.viewer.DesignerFileManager.setupLogger [Converting Inches to Points using dpi: 96]
<silly>@com.protocase.utils.dataDirs.getExecutableDir [executable found in path: C:\Program Files (x86)\Protocase Designer 4]
<silly>@com.protocase.utils.dataDirs.getExecutableDir [executable dir: C:\Program Files (x86)\Protocase Designer 4]
<silly>@com.protocase.utils.dataDirs.checkProgramForLibraryInstallPath [Program Data Dir read from file: C:\ProgramData\ProtocaseDesigner\4.4.5]
<silly>@com.protocase.utils.dataDirs.getProgramDataDir [program data dir: C:\ProgramData\ProtocaseDesigner\4.4.5]
<silly>@com.protocase.utils.dataDirs.getMainLibraryDir [main library found: C:\ProgramData\ProtocaseDesigner\4.4.5\library]
<silly>@com.protocase.utils.dataDirs.getLibraryDir [user library found: C:\Users\shuffield\Documents\ProtocaseDesigner\UserLibrary]
<debug>@com.protocase.io.PDReader.importYAMLSummaryItem [got bad YAML character reading C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Nuts\AC-0420-2 1_4-20 null Nut.pdc]
<debug>@com.protocase.io.PDReader.importYAMLSummaryItem [exception: special characters are not allowed]
<minor>@com.protocase.io.PDReader.parsePDSummary [File C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Nuts\AC-0420-2 1_4-20 null Nut.pdc did not contain a valid part.]
<minor>@com.protocase.library.FileTreeCategory.importChildren [unable to import the file C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Nuts\AC-0420-2 1_4-20 null Nut.pdc]
<debug>@com.protocase.io.PDReader.importYAMLSummaryItem [got bad YAML character reading C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Standoffs\TSO-440-437ZI 4-40 - Ø0.165_ by .437 heat treated carbon Standoff.pdc]
<minor>@com.protocase.io.PDReader.parsePDSummary [File C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Standoffs\TSO-440-437ZI 4-40 - Ø0.165_ by .437 heat treated carbon Standoff.pdc did not contain a valid part.]
<minor>@com.protocase.library.FileTreeCategory.importChildren [unable to import the file C:\ProgramData\ProtocaseDesigner\4.4.5\library\PEMs\Standoffs\TSO-440-437ZI 4-40 - Ø0.165_ by .437 heat treated carbon Standoff.pdc]
<debug>@com.protocase.formula.Parser.parse [Formula: Length]
<debug>@com.protocase.formula.Parser.parse [Answer: Length]
<minor>@Value.setValStr [bad formula found in ]
<minor>@Value.setValStr [exception was: null]
<minor>@com.protocase.things.solids.Sweep.importPD [could not read rotation]
<minor>@com.protocase.things.solids.Sweep.importPD [null]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: extrudedMetalOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: screwOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: extrudedFlushMetalOptions]
<debug>@com.protocase.formula.Parser.parse [Formula: FrontRearThick]
<debug>@com.protocase.formula.Parser.parse [Answer: FrontRearThick]
<debug>@com.protocase.formula.Parser.parse [Formula: TopBottomThick]
<debug>@com.protocase.formula.Parser.parse [Answer: TopBottomThick]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: metalOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: 5-SidedEnclosureSizes]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: 5-SidedEnclosureCoverMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: 5-SidedEnclosureChassisMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: 5-SidedEnclosureOptions]
<minor>@Parser.Operate [NumberFormatException]
<minor>@Parser.Operate [formula: IfElse(Height > (IfElse("MetalType" CONTAINS STRING "Aluminum", IfElse(Chassis Thickness < 11, 5 , 8) , IfElse(Chassis Thickness < 14, 5, 8))), -Chassis Thickness, -(.06) - Chassis Thickness)]
<minor>@Parser.Operate [Operator: <]
<minor>@Parser.Operate [Op1: 11]
<minor>@Parser.Operate [Op2: Chassis Thickness]
<minor>@Value.setValStr [bad formula found in IfElse(Height > MaxHOnePieceBase, -Chassis Thickness, -BendRad - Chassis Thickness)]
<minor>@Value.setValStr [exception was: Bad Formula, got number format error]
<minor>@CoordinateTransform.importYAML [shiftX invalid: IfElse(Height > MaxHOnePieceBase, -Chassis Thickness, -BendRad - Chassis Thickness)]
<minor>@Parser.Operate [formula: -((.06)+Chassis Thickness)]
<minor>@Parser.Operate [Operator: +]
<minor>@Parser.Operate [Op1: Chassis Thickness]
<minor>@Parser.Operate [Op2: .06]
<minor>@Value.setValStr [bad formula found in -(BendRad+Chassis Thickness)]
<minor>@CoordinateTransform.importYAML [shiftY invalid: -(BendRad+Chassis Thickness)]
<minor>@com.protocase.formula.parameters.Parameter.afterImport [could not find MetalType in parser.]
<debug>@com.protocase.formula.Parser.parse [Formula: Thickness]
<debug>@com.protocase.formula.Parser.parse [Answer: Chassis Thickness]
<debug>@com.protocase.formula.Parser.parse [Formula: Cover Thickness]
<debug>@com.protocase.formula.Parser.parse [Answer: Cover Thickness]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountSizes]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountFrontMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountFacePlateConfigurations]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountWithMountingBracketsOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountWithMountingBracketsSizes]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountChassisMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountCoverMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountRearMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountBracketMetal]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountWithMountingBracketsConfiguration]
<minor>@Parser.Operate [formula: -(ChassisBendRad+Chassis Thickness)]
<minor>@Parser.Operate [Op2: ChassisBendRad]
<minor>@Value.setValStr [bad formula found in -(ChassisBendRad+Chassis Thickness)]
<minor>@CoordinateTransform.importYAML [shiftX invalid: -(ChassisBendRad+Chassis Thickness)]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: rackmountConfigurations]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: stepDownRackmountOptions]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: stepDownRackmountSizes]
<minor>@com.protocase.formula.Parser.importYAML [missing included parser: stepDownRackmountConfigurations]
<debug>@com.protocase.formula.Parser.parse [Formula: ChassisThickness]
<debug>@com.protocase.formula.Parser.parse [Formula: CoverThickness]
<debug>@com.protocase.formula.Parser.parse [Formula: FrontThickness]
<debug>@com.protocase.formula.Parser.parse [Answer: Front Panel Thickness]
<debug>@com.protocase.formula.Parser.parse [Formula: MountingBracketThickness]
<debug>@com.protocase.formula.Parser.parse [Answer: MountingBracketThickness]
<debug>@com.protocase.formula.Parser.parse [Formula: RearThickness]
<debug>@com.protocase.formula.Parser.parse [Answer: Rear Thickness]
<silly>@com.protocase.library.PartsManager.Instance [root: C:\ProgramData\ProtocaseDesigner\4.4.5\library ver: 6]
<debug>@minor.init [GL Init Ver: com.sun.opengl.impl.GLImpl]
<silly>@com.protocase.viewer.Renderer3D.init [VBO Support: true]
<silly>@com.protocase.viewer.JDesigner.onLoad [loading file C:\Users\shuffield\Desktop\test.pda]
<minor>@com.protocase.viewer.DesignerFileManager.loadFile []
<minor>@com.protocase.viewer.DesignerFileManager.loadFile [== Loading File test.pda ==]
<silly>@com.protocase.io.PDReader.parsePD [Loading YAML File C:\Users\shuffield\Desktop\test.pda]
<debug>@com.protocase.formula.Parser.parse [Formula: #6]
<debug>@com.protocase.formula.Parser.parse [Answer: #6]
<minor>@com.protocase.things.thing2d.Footprint.attachAssemblyToFace [could not find attachment point to attach footprint: Small Rackmount Handle: x: -0.125000 y: -1.078000 width: 0.250000 height: 2.210000 to face Front Panel]
<minor>@com.protocase.things.attachments.MatePt.setParent [cannot set the parent of a matept to a non-solid. parent: null]
<silly>@com.protocase.things.thing2d.Thing2D.isSameType [trying to check type but type was null]
Thanks for sending me this Doug, I will take a look into it. I will let you know as soon as I have this sorted.
Could I get your email so that I can let you know?
Also, could you attach the file as well so that I can load it up in my protocase designer and take a look?
Here is the Test file.
- Doug
- Doug
- test.zip
- Test file
- (7.47 KiB) Downloaded 580 times
Any resolution on this yet?
- Doug
- Doug
Hey Doug,
Sorry it took me so long to get back to you. This forum's updates don't seem to be working.
Thank you so much for your help, I have created an exclusion zone(keep-out) on countersinks and straightened things up so now the outer ring will be the width of the outer diameter(I was using the wrong formula) of the countersink and it will have a bright red shading so that you can clearer see how close you can put it to other cutouts and such.
Thanks again for the test file.
DavidH
DavidH
