Spaces before or after text get removed. This is to prevent the storage process from accidentally adding spurious spaces. If you need spaces before your text, the only option you have is to actually move the text object. In most cases this should be sufficient.
We will look at changing how the text objects are stored so that spaces before text can be represented.
