When I run in terminal
Code: Select all
sh install.shUsing java version "1.7.0_09"
OpenJDK Runtime Environment (IcedTea7 2.3.4)
Code: Select all
sh install.shCode: Select all
chmod 755 ProtocaseDesigner.sh
Code: Select all
#/bin/sh
install -d ~/ProtocaseDesigner/
cp -R /usr/local/share/Protocase\ Designer/library ~/ProtocaseDesigner/
LD_LIBRARY_PATH=/usr/local/lib/Protocase\ Designer/:/usr/local/lib/Protocase\ Designer/lib/:$LD_LIBRARY_PATH java -jar /usr/local/lib/Protocase\ Designer/jdesigner.jar >> ~/ProtocaseDesigner/error.log 2>&1
Code: Select all
mkdir ~/ProtocaseDesigner
cp -R /usr/share/jdesigner/library ~/ProtocaseDesigner/
Code: Select all
cp -R /usr/share/jdesigner/library ~/ProtocaseDesigner/Code: Select all
cp: cannot stat `/usr/share/jdesigner/library': No such file or directoryCode: Select all
Code: Select all
install -d /usr/local/share/Protocase\ Designer
cp -R library /usr/local/share/Protocase\ Designer/
Code: Select all
