Ver 4.2.13
With 4U rack mount chosen and global preferences for dimensions in mm if I change anything in edit enclosure properties it blows the model apart as it now reads the depth (converted from inches to mm) mm as inches! To reset this I need to re-enter the value in inches and allow it to convert back to mm via 'OK' to exit. - This seems to be a problem with all models when default of mm is chosen. If you re-enter the 'edit enclosure properties' menu option the inches converted to mm are now read as inches and can throw an error, need to convert mm to inches before coming out to get model back.
It appears instant quote and purchasing menu items do not work if behind a proxy. Can we have a setting to allow proxy set up. (or is this as I am a UK user?)
On selecting help in face editor no menu available nothing happens.
Would it be possible to allow the user to change the module chassis widths in rackmount, in a future version? I want slightly wider than the 425 standard that is given.
Notwithstanding the above a very competent peice of software saving loads of time trying to explain cases and draw cads for third party builders also for local design reviews, well done on the efforts of this tool.
						Annoying noted bugs 4.2.13 (1 very annoying)
Re: Annoying noted bugs 4.2.13 (1 very annoying)
Hello, somehow this post slipped by me. I am sorry for the hassle, and thank you for the compliments! You will be happy to know that the current testing version
http://www.protocasedesigner.com/RELEAS ... -Nov26.exe
does not have this problem and also labels the units in the properties dialog for clarity.
The constraints are still listed in inches however (where it says things like Width must be 2" greater than Height for all enclosures greater than 3"x3"x3").
