Bare Metal Masking
Posted: Fri Feb 03, 2012 3:32 pm
				If you need bare metal (for instance for electrical connection) the best way to indicate that is to make a construction rectangle and add a note to it asking for masking.
			- Press the draw type selector (small button on upper end of left toolbar)
 - Select Construct
 - Press the rectangle tool button (on the left toolbar)
 - Draw a rectangle where you want the masking
 - Enter the note in the note tool on the right
- Mouse into the Note box
 - Type: Please mask this area during paint so that it is bare
 - if you need the opposite flange masked, note that in this box as well since you can't draw anything in flanges
 - click on one of the arrows above the note tool or in the 2D editor to make sure your note is added.
