Issue with grouping silkscreen and PEMs
Posted: Wed Jan 11, 2012 12:33 pm
Here's the problem: I place a silkscreen rectangular shape on the inside surface of the bottom panel of a 1u rack mount chassis. I'm using this as a template as to where I can place certain items in this enclosure. I then place PEM studs within the silkscreen outline. This now gives me an outline of the item I will be placing in the box and studs that are located exactly where they need to be for installation. Next I select the studs and silkscreen and click group. Great! Everything moves around together so I can play with placement and orientation of my parts without having to have anything on hand. I can even copy and past since this particular enclosure will have multiple of the same item in it. I can also go back and forth from 3D view and panel edit and everything looks good. As soon as I close the program and open it and my file back up, the silkscreen is on the OUTSIDE of the panel and PEM studs are facing the inside (which is correct). Why did my silkscreen move!
If I place a silkscreen by itself it stays where I put it. But i want to create templates (outline of each item and mounting studs) for all the different items we install in these boxes.
The same goes if I save the grouped items to my library. They stay in the library until I close the program then they disappear. This happens on 4.1.8, 4.2 and 4.2.3.
Very frustrated. I spent a lot of time creating and placing template to have them all ruined and lost when I closed the program and re-opened it.
Jeremiah
Jeremiah
