Protocase Designer 4 and Windows 7 64 bit
Posted: Thu Jul 28, 2011 8:26 am
If you are running Windows 7 64 bit, then you need the 64 bit Java Virtual Machine. Chances are you don't have it because http://www.java.com recommends the 32 bit version for reasons of browser compatibility. However, you can have both installed on your computer with no problems so please use the following link to install the 64 bit version:
http://download.oracle.com/otn-pub/java ... ws-x64.exe
Then Protocase Designer should run fine.
