Cutout Placement to Align with Standoffs
Posted: Wed Feb 10, 2010 11:13 am
One of the most common questions we get is how to account for the material thickness when trying to align say a DB-9 connector to a circuit board sitting on standoffs. Fortunately, standoffs aren't actually attached to the inside surface - they are embedded in the face. This means that if the measurement of a standoff is 1/4", then that is 1/4" from the outside of the box. When you are editing a front face cutout, if you edit the properties (right click) the y coordinate is relative to the outside of the bottom of the box. So the answer is you don't have to worry about it!
Re: Cutout Placement to Align with Standoffs
Posted: Thu Mar 01, 2018 3:07 pm
by Panometric
Is this still strue with the extruded sides? It looks like there is an offset in both Z and Y of say the bottom origin compared to the front origin.
2018-03-01 11_05_16-Front Panel Face Editor.png (18.11 KiB) Viewed 18464 times
Posted: Mon Mar 05, 2018 4:19 pm
by Colin
Hey Panometric,
it would not hold true in this case. The standoff is inserted into the bottom plate, which sits a distance above the origin of the front face.
