change stud direction?
chas
Post by chas »
if i add a stud to the rear of the enclosure it faces inward. i would like it to face outward. the intended use is as a "chassis ground". i tried editing the inside face of the rear panel, but still the stud faces inward.
Re: change stud direction?
There are two ways of placing studs facing outwards:
    • Place the stud
    • right-click on the stud and de-select the "faces inside of case" checkbox
  • select the stud to place but don't place it
  • press the middle button on your mouse
  • place the stud
I hope that helps!
