silkscreen help
silkscreen help
Hi, i have a case im building, the case is going to be black. i would like to use white silkscreen on my case but when i export my silkscreen file to edit it the backround is already white on the file makeing it impossible to add white silkscreen to the png file. how can i add white silkscreen to a case that is to be painted black when silkscreen exports a white backround? thanks for your help, steve
Re: silkscreen help
That is a limitation of the current program. It will be fixed in the next version. In the meantime, open the template, change the background to transparent, and make your silkscreen. You won't be able to import it onto your case but you will be able to send it along with your case and our graphics designers will be able to place it on your case.
The next version, due out in mid February, will support white-on-black silkscreens.
Protocase Designer Team Member
