PEMs Manager in PD Version 3.11
In PD Version 3.11 there is a tool called "PEMs Manager". This will be removed in version 3.12 for future down loads (not sure of exact date). This feature is currently for internal (Protocase) use only. It is used to create new fastener sizes that Protocase has available. If you have this tool available in the version you are using you should avoid using it. If you require a fastener that is not available in the stocked list please communicate your custom requirement via email.
